1. Provides a mechanism for you to configure and conduct your own device
test steps. It takes the advantage of the sound card’s (or other ADC/DAC
hardware’s) capability of simultaneous input & output, to generate a
stimulus to the Device Under Test (DUT) and acquire the response from
that device at the same time. Different stimuli can be generated and the
response can be analyzed in different ways.
2. Supports 23
instructions with corresponding parameters. Support using
variables in scripts.
3. Parameters to be
tested can be selected from 242 DDPs and 16 UDDPs, including RMS value,
Peak Frequency, Sound Pressure Level, RPM, Gain, THD, etc.
4.
Test results (e.g. Gain vs Frequency, Phase vs Frequency, etc.) can be
plotted in up to 8 X-Y plots and reported in one textual log window
called Device Test Plan Log in
real time. The data in X-Y Plots can be exported as TXT files or copied into the clipboard as text and later pasted into other software such as Microsoft Excel for further analysis. The graph of the X-Y plot can be copied into the clipboard as Bitmap image and later pasted into other software such as Microsoft Word. The graphs can also be printed out directly or exported as BMP files. The data in the Device Test Plan Log can be saved as a TXT file.
5. Support batch file processing and batch signal
event capturing and storing.
6. A device test plan can be
created, edited, modified, saved, locked, reloaded, executed.
7.
There are two types of device test plans: locked and unlocked. A locked
device test plan cannot be modified within the software after it has
been created.
8. Support Pass/Fail check. Support connection with
external systems through serial communication.
9. Supports
Multilingual User Interface under Windows 2000, XP, Vista, 7, 8,
8.1, 10, 11
and above. Currently supported languages are English, French, German,
Italian, Portuguese, Spanish, Russian, Simplified Chinese, Traditional
Chinese, Japanese and Korean.
Pass / Fail Test
Gain and Phase Plot using Stepped Sine
THD, THD+N, SNR, Magnitude Response vs Frequency
Crosstalk vs Frequency
THD and THD+N vs Magnitude and Power
IMD vs Magnitude and Power
Output
THD vs Output dBFS of a DAC
Output dBV vs Output dBFS of a DAC (Input-Output Linearity
Graph) (dBV is measured with a narrow band in frequency
domain to exclude noises)
Car Aircon Howling Test System with PLC communication using
Modbus RTU Protocol
Subwoofer Max. Output SPL Test according to CEA-2010
