Multi-Instrument - Data Logger
1. Provide long time data logging function for 196 Derived Data Points (DDP) and 16 User Defined Data Points (UDDP), including RMS value, Peak Frequency, Sound Pressure Level, RPM, THD, etc.
2. Up to eight data logger windows can be opened and each window can trace up to 8 variables. You can configure which derived variables to be logged.
3. Color of each trace can be configured.
4. The range of Y axis can be configured. Y axis can be displayed in linear or logarithmic scale.
5. X axis is always a time axis with accuracy in minisecond. The span of X axis can be configured. The screen automatically scrolls as new data are continuously fed into the right of the window.
6. Data are logged in text format. Each log file contains a maximum 32767 (configurable) lines of data. The file name reflects the time stamp of that file. Log files can be reloaded into the data logger window for display.
7. Three logging methods: Fastest (i.e. whenever new data are available), Time Interval (i.e. whenever new data are available and the specified time duration has elapsed since the last update), Update Threshold (i.e. whenever new data are available and the change compared with the last update exceeds the specified update threshold).
8. The data in the graph can be copied into the clipboard as text and later paste into other software such as Microsoft Excel for further analysis. The image of the graph can be copied into the clipboard as Bitmap image and later paste into other software such as Microsoft Word.
9. Supports Multilingual User Interface under Windows 2000, XP, 2003, Vista, 7, 8, 10 and above. Currently supported languages are English, French, German, Italian, Portuguese, Spanish, Russian, Simplified Chinese, Traditional Chinese, Japanese and Korean.
USB Data Logger
8×8 Derived Data Points can be logged simultaneously
