You're viewing an older version of this page. Visit the new version.
VT USA-268A/B
VT-USA-168
PC based USB 32-bit-float, Huge-dynamic-range, Ultra-low-noise, Real Time Underwater Sound Analyzer                                  Manual
VT USA-268A     US$1499.95     Free Express Shipping
VT USA-268B    US$1499.95     Free Express Shipping
VT USA-268A and VT USA-268B come with the same XLR-to-USB audio interface but with different hydrophones.
1. Introduction
VT USA-168, a PC based USB Real Time Underwater Sound Anayzer
VT USA-268A and VT USA-268B are PC-based real-time underwater sound analyzers with ultra-low noise and a huge dynamic range, covering 9 Hz to 92 kHz (-3 dB), powered by the comprehensive virtual instrument software Multi-Instrument®.  Each analyzer includes a high-sensitivity hydrophone with a built-in preamp and an XLR output connector, plus an XLR-to-USB audio interface. The hydrophones can withstand a static water pressure up to 350 m and drive cables up to 250 m with negligible signal degradation.
The hydrophones in the two analyzers are manufactured with the same industrial-grade sensors under strict quality control, making them well-suited for absolute underwater sound level measurements in marine and industrial environments. The hydrophone of VT USA-268A is assembled with a 150g sliding stainless steel weight on its cable to provide negative buoyancy and stable positioning in mild wind and current conditions. The hydrophone of VT USA-268B features a standard panel-mount design, making it well suited for integration into systems, such as autonomous recording units, autonomous or remotely operated vehicles, and dive camera enclosures.
The XLR-to-USB audio interface used in the analyzers has two ADCs working in tandem to create a single output data stream in 32-bit float format. One “low gain” ADC is optimized for high-level signals, and the other “high gain” ADC is optimized for low-level signals.  This state of the art dual-ADC architecture provides an unmatchable dynamic range compared with the conventional single ADC approach. It is possible to capture underwater sounds at low levels with high fidelity and at high levels without clipping, all without the hassle of manual analog gain adjustment.
2. Package Contents
1) Hydrophone with a built-in preamp and an integrated XLR cable
2) XLR-to-USB Audio Interface
3) USB cable (1 m)
4) CD (contains the copy-protected Multi-Instrument Software)
5) USB hardkey (contains a Multi-Instrument Pro License)
6) Carrying Case
3. Optional Items
1) An additional XLR hydrophone and its accessories
2) Software license upgrade
4. VT USA-268A/B Hardware Configuration
  USA-268A USA-268B
Hydrophone
with a Built-in Preamp
USA-168A-Hydrophone
Default Cable Length: 10 m
USA-168B-Hydrophone
5. VT USA-268A/B/C Overall Specifications
USA-268A
USA-268B
Frequency Range (-3dB)
9Hz ~ 92kHz
Sound Level Measurement Range
50dB~185dB (typical)
Operating Depth
< 200m
Sampling Rate
44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Bit Depth
32-bit Float / 24 bit
Number of Input Channel
2
Number of Output Channel
2
Direct Monitoring without Passing Through Computer
Supported
Frequency Accuracy
0.001%
Frequency Weighting
Flat, A, B, C, ITU-R 468
Time Weighting
Linear, Exponential
(Equivalent continuous sound level (Leq) fully complies with IEC61672)
Octave Analysis
1/1,1/3,1/6,1/12,1/24,1/48, 1/96 (Complies with IEC61260)
Other Functions
Much more functions are described in the software manual.
USB interface
USB 2.0, driver installation required
Input Isolation
No (Isolation can be achieved through a USB high speed isolator)
Power Source
USB bus power (Type C), DC 5V power supply (Type C)
Power Consumption
Max. 2.5W
System Requirements
Windows 10/11, 32 bit or 64 bit.
Minimum Screen Resolution: 1024 × 600
Calibration Accuracy
±2dB
6. Hydrophone Specifications
USA-268A
USA-268B
Transducer Type
Thin-wall PZT
4.3Hz ~ 110kHz
Sensitivity
-180dB re: 1 V/μPa   (i.e. 0.001V/Pa)
Horizontal Directivity
+0.2/-1 dB @50kHz
Vertical Directivity
+0/-5.9 dB @50kHz
Survival Depth
350 m
Operating Temperature Range
-10℃~+80℃
Acoustic Overload Pressure
188 dB
Size
Φ12mm × 43mm
Weight (hydrophone only)
8 g
Specific Gravity (hydrophone only)
1.4
Wetted Materials
Polyurethane, anodized aluminum
Added Weight
150g
No
With Built-In Preamp
Yes
Connector
XLR (pin 1: ground, pin 2: hot, pin 3: cold)
Power Supply
48V Phantom
7. XLR-to-USB Audio Interface Specifications
Input Impedance
Max. Voltage
Dynamic Range
XLR Phantom Power
Left (Input 1):
XLR/TRS/TS(HiZ) Combo Jack
XLR: 2.7 kΩ
TRS: 4 kΩ / 1 MΩ (when HiZ on)
XLR: 2.35Vp
TRS: 23.0Vp / 4.30Vp (when HiZ on)
XLR: 134 dB
TRS: 129 dB
TS(HiZ): 123 dB
48V
Right (Input 2):
XLR/TRS Combo Jack
Output Impedance
Max. Voltage
Left (Output 1): TRS (balanced) Jack
100Ω
9.0Vp
(adjustable through volume knob)
Right (Output 2): TRS (balanced) Jack
Headphone
12Ω
4.4Vp
MIDI
IN/OUT (5-pin DIN connectors)
Input Frequency Response
44.1 kHz: 20Hz~20kHz, +0.1 dB / −0.2 dB
-3dB: 9Hz~21.8kHz
48 kHz: 20Hz~20kHz, ±0.21dB
-3dB: 9Hz~23.8kHz
96 kHz: 20Hz~40kHz, ±0.22dB
-3dB: 9Hz~47.6kHz
192 kHz: 20Hz~80kHz, +0.1 dB / −0.2 dB
-3dB: 9Hz~91.8kHz
TRS Output Frequency Response
44.1 kHz: 20Hz~20kHz, +0.0 dB / −0.1 dB
-3dB: 1.9Hz~21.1kHz
48 kHz: 20Hz~20kHz, ±0.1dB
-3dB: 1.9Hz~22.8kHz
96 kHz: 20Hz~40kHz, ±0.1dB
-3dB: 2.1Hz~45.6kHz
192 kHz: 20Hz
~80kHz, +0.0 dB / −1.0 dB
-3dB: 2.1Hz~93.2kHz
Headphone Output Frequency Response
44.1 kHz: 20Hz~20kHz, +0.0 dB / −0.5 dB
-3dB: 1.5Hz~20.9kHz
48 kHz: 20Hz~20kHz, ±0.3dB
-3dB: 1.5Hz~22.8kHz
-3dB: 1.6Hz~45.6kHz
192 kHz: 20Hz~80kHz, +0.0 dB / −1.0 dB
-3dB: 1.7Hz~95.2kHz
USB Connector
Type C
Power Consumption
Max. 2.5W
Dimension
164 mm (W) × 105.5 mm (D) × 65 mm (H)
Weight
355g
Typical Frequency Response
8. Some Examples
1. Orca vocalizations recorded
Orca Vocalization Recorded using USA-168A
2. Humpback vocalizations recorded
Humpback vocalizations recorded using USA-168A
